#1 2020-05-27 15:11
maryrabbit
Regex match before / after year? e.g. 1994 > (1994)
Example, adding parenthesis to before and after the matching year pattern / `\d{4}`:
Name:
Batman 1994
Superman (2003)
New Name:
Batman (1994)
Superman (2003)
I tried positive lookahead/behind but reNamer throws unrecognized modifier error
#2 2020-05-27 16:15
Re: Regex match before / after year? e.g. 1994 > (1994)
Hello and welcome.
The most simplest way is to add parenthesis to all years, if have parenthesis already or not,
and add next an Replace Rule (https://www.den4b.com/wiki/ReNamer:Rules:Replace)
to change doubled parenthesis by single one:
Find: ((*|*))
Replace: (*|*)
The regex syntax can be read there
Right now no lookaround implemented.
You could use a "must no match" expression [^...]
Batman 1994
Superman (2003)
Batman (1994)
Superman (2003)
USE:
Regular Expressions:
Expression: "[^(](\d{4})[^)]"
Replace: " ($1)"
[x] skip extension
#3 2020-05-27 16:18
The following two rules should do the job:
1) Regular Expressions: Replace expression "\b(\d{4})\b" with "($1)"
2) Replace: Replace all "((" with "(", "))" with ")"
#4 2020-05-27 18:04
eR@SeR
Or you can use one rule:
1) Regular Expressions: Replace expression "\(?(\d{4})\)?" with "($1)" (skip extension)
#5 2020-05-29 11:56
maryrabbit
It works! thank you @stefan @den4b @eR@SeR !!!
