#1 2020-07-14 00:55
Peweh
Change Tray Color
Dear Developer
We use Shutter Pro to check the Connection to our Server.
If ping stopped for 10 Seconds "Message"......
So now my Problem ist, when my connection works, the Icon is always red, when it stopped it turns to Grey.
Is it maybe possible to do "Actions" and change the Tray Icon Color ?
So if ping is NOT Stopped the Tray Logo should be green so my Employe knows its working everything fine.
Im using Windows 7 so i think i cant change this Setting in windows. (It's only working in Win 10)
Thanks in advance for checking this function.
Best Regards
Pascal
