#1 2020-08-23 10:13
duncanb
Lasso function in the file table?
It seems that versions subsequent to v5.74 lack the 'lasso' function.
I find this function quite useful which is why I continue using 5.74.
Is there a reason for its removal?
#2 2020-08-23 12:29
Re: Lasso function in the file table?
This feature was disabled due to bugs in a 3rd party component. However, a quick test just showed that the previously experienced issues are no longer present, so let's try re-enabling the lasso selection.
ReNamer 7.2.0.5 Beta:
Restored the ability to draw the selection rectangle with a mouse in the files table.
Try the latest development version.
Related topic: Handle mouse input events in the Listview.
#3 2020-08-24 07:48
duncanb
Thanks very much.  I shall give the Beta a go.
BTW, thanks for Renamer -- I use it everyday and am not sure what I would do without it.
