#1 2020-12-20 09:25
swanx
Renamer for txt files
hi, i have been using your Renamer for many years. Great.
den4b: why not create such a txt program??
notepad++ work with regex but regex code are not easy... it would be nice to be able to use a program similar to Renamer to edit the txts...
can it be done? or can anyone on this forum advise me on any program that does this?
thank you, greeting everyone!
#2 2020-12-20 09:36
Re: Renamer for txt files
Have you tried the Analyze dialog in ReNamer?
https://www.den4b.com/wiki/ReNamer:Analyze
It doesn't have any fancy features of a text editor, but it allows you to apply your renaming rules to any arbitrary text.
There are also options to apply your renaming rules to the Clipboard content.
#3 2020-12-20 15:02
swanx
very useful, thank you.
and no, never tried before because no such entry is present in the submenus of your program. if you had not indicated the link here i would never have known that pressing Shift+A opens the Analyze tool window !!
that's what i needed.
a program like this "Analyze tool" aside would be great, really useful that would allow you to bypass boring regex for np++
#4 2020-12-21 08:40
swanx
I hope you create a txt editing program with functions like in Analyze tool.
it would be a really nice move towards regex complexes and i think it would be a remarkable success, if well publicized as Renamer that everyone knows by now!
#5 2020-12-24 12:34
It is hiding in plain sight! big_smile
There is a button, and it is also found in the Options menu, labelled "Analyze sample text".
#6 2020-12-24 12:41
It is unlikely. But there is a plan to implement command line options for applying renaming rules to any arbitrary text. This should allow an easy integration of ReNamer's features into almost any text editor.
#7 2020-12-24 14:41
swanx
oh yes! my mistake!
But there is a plan to implement command line options....
this plan for future release?
#8 2020-12-25 14:38
Yes.
