#1 2021-06-03 23:24
Lauraq
Change case of name differently for Author, Title and comment part
uppercase and capital letter very hard sad
Hi smile
I have many mp3 that are like:
11 - Simone filippi & Luca alfonso rossi - Cuore spezzato (Feat Carl brave)
Can I have
11 - Simone Filippi & Luca Alfonso Rossi - Cuore spezzato (feat Carl Brave)
Basically I would like all capital letters before "-" and then only the first capital letter
And, when there is "(feat " everything that comes after is capitalized
Thanksssss ^_^
#2 2021-06-06 09:05
skiwi
Re: Change case of name differently for Author, Title and comment part
Try the Case rule, this will largely do what you want
Then in another rule change change "(F" to "(f", change "Spezzato" to "spezzato" etc
#3 2021-06-06 10:21
Lauraq
sorry but my english is bad and i don't know technical things. Can you tell me step by step what to do? Thank you smile
However, I think you have misunderstood, mine is an example, I don't have to change just "spezzato" big_smile
#4 2021-06-06 11:16
skiwi
Add rule "Case". chose case change (see https://www.den4b.com/wiki/ReNamer:Rules:Case) or accept the default
Preview the result. (see https://www.den4b.com/wiki/ReNamer:Previewing_files)
Add rule "Replace" to restore any lower case you want, (see https://www.den4b.com/wiki/ReNamer:Rules:Replace)
E.g. find "(Feat" and replace with "(feat"
Rename the files (see also https://www.den4b.com/wiki/ReNamer:Renaming_files)
#5 2021-06-06 21:42
Lauraq
thanks ... now is there someone who can really help me? Thank you
please @den4b save me from these "special aids" smile
#6 2021-06-06 23:56
eR@SeR
Lauraq, try this rules combination:
1) Case: Capitalize every word (skip extension), Force case fragments "feat"
2) Regular Expressions: Replace expression "([a-zA-Z]+) ([a-zA-Z ]+)*(\(feat[^)]+\))" with "$1 \L$2 $3" (skip extension)
3) Clean Up: Normalize spaces, Fix spaces (skip extension)
I added more possible examples just in case they exist:
11 - Simone filippi & Luca alfonso rossi - Cuore spezzato something more (Feat Carl brave)
11 - Simone filippi & Luca alfonso rossi - Cuore (Feat Carl brave)
11 - Simone filippi & Luca alfonso rossi - Cuore (Feat Carl)
11 - Simone filippi & Luca alfonso rossi - Cuore (Feat. Carl)
Luca - Cuore (Feat Carl brave)
To:
11 - Simone Filippi & Luca Alfonso Rossi - Cuore spezzato something more (feat Carl Brave)
11 - Simone Filippi & Luca Alfonso Rossi - Cuore (feat Carl Brave)
11 - Simone Filippi & Luca Alfonso Rossi - Cuore (feat Carl)
11 - Simone Filippi & Luca Alfonso Rossi - Cuore (feat. Carl)
Luca - Cuore (feat Carl Brave)
Note: On my end ReNamer freezes up to dozens of seconds while using Analyze dialog. It might happen on yours too when adding files.
Denis, RegEx rule by some unknown reason takes too long to process. Can you check why it takes too long? I debugged it and it processes matched strings up to 14 steps.
#7 2021-06-07 10:57
Lauraq
Thank you so much for the help but my OLD PC freeze like yours but after a few minutes I was forced to close ReNamer because it was no longer working sad
I hope that the problem is solved because your solution is fantastic because it covers all possible variables! smile smile smile
#8 2021-06-07 13:10
eR@SeR
First add rules, then add files and wait until gets responsive (it might take minutes - depending on how many files you added, can't tell).
It looks like it is not fantastic at all tongue try to wait and then claim it as deserved. Good luck! smile
#9 2021-06-07 16:28
Lauraq
nothing to do sad I have add only 7 file (with the same name of your example) and after 10 min the prog is always freezed.
My PC is a Intel Core i7 LGA1156 i5-860 with 8 giga RAM
it is not possible to divide the command into several separate commands?
#10 2021-06-09 13:21
eR@SeR
Provided one no. Maybe someone can write a Pascal script which process files faster.
