#1 2022-03-19 11:09
Shutter 4.5
Shutter 4.5 has been released.
Summary of changes:
  • Added "Program Output" event for monitoring the exit code of a program.
  • Added "Port" event for checking if a network port is open or closed.
  • Added an option to the "Ping" event to trigger when the host is responding, rather than not responding.
  • Added an option to the "File Size" event to trigger when the file size is below a certain size.
  • Added an option to the "User Inactive" event to trigger when the user becomes active after a period of inactivity.
  • Added an option to open a new instance via the File menu, also accessible via Shift+Ctrl+N shortcut.
  • Added an option to keep the display on and prevent screensaver.
  • Updated OpenSSL library to version 1.1.1g. Use the highest TLS/SSL version mutually supported by the client and the server, including SSLv3, TLSv1, TLSv1.1, TLSv1.2 and TLSv1.3. Older OpenSSL library files are automatically deleted by the installer. If upgrading a portable version, you should manually delete "libeay32.dll" and "ssleay32.dll" files from the application directory.
  • Fixed: Settings are not saved when terminating the application via the tray icon.
  • Fixed: Application is not terminating via the web interface or the planner action when the option to minimize on close is enabled.
  • Added language files: Hungarian, Spanish, Corsican.
  • Updated language files: Japanese, German, Polish, Russian.
See the full changelog between v4.4 and v4.5 for more details.
