#1 2023-11-28 08:54
lingyuk
Accidentally created a instant sleep-loop and now I can't disable it.
Even when I reinstall, as soon as shutter starts, it hibernates the PC.
How can I fix it?!
Thank you!
#2 2023-11-28 09:00
lingyuk
Re: Accidentally created a instant sleep-loop and now I can't disable it.
Is there a way to change the settings before launching shutter?
I don't know why the settings don't reset upon uninstall.
#3 2023-11-28 09:01
lingyuk
It happened when I accidentally forgot to assign a trigger for the hibernate. So it just seems to hibernate instantly when the program is launched.
#4 2023-11-28 12:54
The user generated settings are kept back to allow in-place upgrades.
Delete these files to have a clean start:
%USERPROFILE%\Documents\den4b\Shutter
If Shutter is configured to start automatically with Windows, you can boot Windows into Safe Mode and then disable Shutter.
