#1 2007-09-12 01:55
mhpandya
Rules table disappeared
Hi
In renamer 5 have you changed the gui
i do not see the box for rules
#2 2007-09-13 00:07
Re: Rules table disappeared
This is a result of upgrading while using the "Remember last position and size" option from the previous version. In v5.00, this option also remembers the height of the rules table, but in old ReNamer.ini file that field was not defined, meaning that the rules table would get a default height of 0px, making it hidden. Simply turn that option off, restart ReNamer, and set that option back on.
Soon I will release an update which will fix this issue. Sorry for the confusion.
#3 2007-09-30 21:11
