#1 2007-10-01 06:00
MaJ
ReNamer - custom serialize with letters (a,b,c...)
love your software, it's simple, powerful, and very handy.
Because of a server standard, I need to serialize using letters: a,b,c,d,.....,y,z,a1,b1,...etc.
Can that be done?
Thanks a lot,
Ma.
#2 2007-10-05 12:47
Re: ReNamer - custom serialize with letters (a,b,c...)
Yes, it can be done, using PascalScript rule.
If you have no experience in pascal/delphi programming, I can help you writing this script.
I will need to know variations of the serializing sequence... and where to insert it in the name.
For example, below is the code to append single letter from "abc...xyz" to each name, one-by-one.
  I: Integer;
  Letters: string;
  Initialized: Boolean;
  if not Initialized then
    Letters := 'abcdefghijklmnopqrstuvwxyz';
    Initialized := True;
    I := 1;
  if I > Length(LETTERS) then I := 1;
  FileName := FileName + Letters[i];
  I := I + 1;
#3 2007-10-07 18:33
eagle
This will go in this sequence: a,b,c,...,x,y,z,a1,b1,c1,...,x1,y1,z1,a2,b2,c2,...,x2,y2,z2,... ... ... x999999,y999999,z999999,.....
  I, J: Integer;
  Letters: string;
    I := 1;
    J := 0;
    I := 1;
    J := J + 1;
  if J > 0 then
    FileName := FileName + IntToStr(J);
  I := I + 1;
#4 2007-10-07 21:30
Good job, eagle! smile
Here is a slightly modified version of your code, which will skip the extension:
  I, J: Integer;
  Letters, Pad: string;
    I := 1; J := 0;
  if I > Length(Letters) then
    I := 1; J := J + 1;
  Pad := Letters[i];
  if J > 0 then
    Pad := Pad + IntToStr(J);
  FileName := WideStripExtension(FileName) +
    Pad + WideExtractFileExt(FileName);
  I := I + 1;
#5 2017-06-02 16:52
ReNamer v6.7.0.2 Beta:
Added a selection of numeral systems to the Serialize rule: Decimal digits (0..9), English letters (a..z), Roman numerals (I,II,III,IV,...), Simplified Chinese, Custom alphabetic and Custom numeric.
