#1 2007-10-31 20:43
John In PS
Feature request for ReNamer 5.10 - Cursor focus
When you click on "+ Add" to open the "Add Rule" dialog, the cursor focus should default to the first field in the "Configuration" box.
For example, when you choose "Remove" from the "Add Rule" list, the cursor should be in the "Remove" field in the "Configuration" box.
A minor change to be sure, but anything that saves mouse clicks is most welcome!  Thanks for a great little program.
#2 2007-11-03 23:04
Re: Feature request for ReNamer 5.10 - Cursor focus
But some people select rules with a keyboard (up and down arrows), and they wouldn't want the focus to jump to the configuration box straight after they select another rule. Simply press a "Tab" key - it which will transfer the focus to the next control, i.e. configuration box.
