#1 2007-11-12 16:43
PascalScript: WideExpand_Environment_Variable
It's  me again, sorry. roll
Just a question:
It seams i can't use environment-variables in Pascal script?
like
FileWriteContent('%Temp%\ReNamerCount.txt', IntToStr(I));
Error
Preview process has been terminated due to a critical error:
Pascal Script Execute:
[Line 4] Exception: Cannot create file "D:\ReNamerBeta 12.11\Help\%temp%\ReNaCount.txt".
Das System kann den angegebenen Pfad nicht finden.
OK
Is there something like
vTEMP := WideExpandEnvVar(%tmp%) ?
FileWriteContent( vTEMP + '\ReNamerCount.txt', IntToStr(I));
I just try to use this for FileCounter.pas:
var   I: Integer;
 I := I + 1;
 FileWriteContent('C:\ReNamerCounter.txt', IntToStr(I));
// later in an another script use ==>  FileCount := FileReadLine('C:\ReNamerCounter.txt', 1);
#2 2007-11-22 01:02
Re: PascalScript: WideExpand_Environment_Variable
I think you'll be happy to know that I've added this new function big_smile
function WideGetEnvironmentVar(const VarName: WideString): WideString;
No need for the "%" signs, just use WideGetEnvironmentVar('TEMP').
TRY: ReNamerBeta.zip
#3 2007-11-22 20:44
Yes that helps, many thanks Denies :D
I have test this with some files only. Will test more over the weekend.
FilesCountWrite.pas
  I: Integer;
  vTEMP: WideString;
 I := I + 1;
 If I < 2 Then
 vTEMP := WideGetEnvironmentVar('TEMP');
 FileWriteContent(vTEMP + '\ReNamerCounter.txt', IntToStr(I));
FilesCountRead.pas
  I: Integer;
  vTEMP, vFileCount: WideString;
  I := I + 1;
 If I < 2 Then
 vFileCount := FileReadLine(vTEMP + '\ReNamerCounter.txt', 1);
 FileName := WideExtractBaseName(FileName) + ' (' + IntToStr(I) + ' of ' + vFileCount + ')' + WideExtractFileExt(FileName)
How to use:
- add files
- load Pascal Rule FilesCountWrite.pas
- load Pascal Rule FilesCountRead.pas
- press Preview
- disable Pascal Rule FilesCountWrite.pas
- check New Names
If you change the amount of files (add or uncheck some) THEN
- enable Pascal Rule FilesCountWrite.pas
- (maybe press Preview)
Great tool Denis
greeds
#4 2007-12-07 13:11
It's good too know that you are making a lot of use out this little function big_smile
