#1 2006-04-28 11:07
LawOfNonContradiction
ReNamer: ini filename follows exe
I can rename ReNamer.exe to something else, but it still generates ReNamer.ini.  I would like it if [NAME].exe looked for [NAME].ini instead.
Ex.  RN.exe loads RN.ini,  932.exe loads 932.ini
edit: I just read about the 'Presets' directory.  Could you also add an option to name it [Name]_Presets.  I like to keep a bunch of utilities in one directory and "presets" is a bit vague.
big_smile
#2 2006-04-29 01:07
Re: ReNamer: ini filename follows exe
http://www.redbrick.dcu.ie/~den4b/Projects/ReNamer/ReNamerBeta.zip
Try now! RN.exe will generate RN.ini smile
About "[Name]_Presets"... but I like folder "Presets", as well as new "Scripts" folder wink
I don't want to make a mess by prefixing all the folders...
#3 2006-05-05 11:14
wow two new features..  at least the matching ini will make USB flashdrive use much nicer smile  Perhaps you'll consider an *option* to prefix directory names...  cool
#4 2006-05-06 22:05
Hmm... I don't know, I like "Presets" and "Scripts" folders as they are big_smile
