#1 2006-04-28 11:13
LawOfNonContradiction
Renamer: clear rules list
Please consider adding an option to the Settings:Process tab
[ ] Clear Rules List when ReNamer loads
Right now I have a preset for 'no rules' to erase all the rules.  Sometimes is good that ReNamer remembers the Rules Lists between uses.. sometimes its not.
big_smile
#2 2006-04-28 11:39
Re: Renamer: clear rules list
On the first place, do you know why ReNamer remembers the rules between uses?
Because you have ticked the "Save rules configuration of exit, load on startup" option, in Settings, General tab wink
Simply unmark that option, and ReNamer will not load any rules on startup!
Alternatively, there is a handy shortcut to clear the rules list Shift+Del (in popup menu).
#3 2006-05-05 11:16
yikes  oops.
