#1 2008-09-16 00:01
admsupport
Serialize with same name and strip last occurrence of "-"
Hi, I am new here so, hello everyone and thank to Mirster Denis for his work.
2 simple questions:
a) how to rename multiple files with different names into a single name + serialize (e.g New file 001, New file 002, etc) with only 1 or 2 rules?
So far I need 3 rules 1) delete 2) insert 3) serialize
b) how to stripe only the last occurrence: "-" but keep the first one, in a file like this one:
Sample Name - Sample Name - Sample Name
PS. does anybody know a good tutorial for a (complete) beginner about Regular Expressions
#2 2008-09-16 07:11
Re: Serialize with same name and strip last occurrence of "-"
Welcome admsupport
Is it a matter to use two rules only instead of three ? wink
b) how to stripe only the last occurence: "-" but keep the first one, in a file like this one:
Did you see "Remove"-Rule with "()Last"-feature?
I think this could solve your question?
PS. does anybody know a good tutorial for a (complet) beginner about Regular Expressions
First start: http://www.den4b.com/forum/viewtopic.php?id=450
Here is my older list of links to regex help, some may be out datet? sorry.
Here are some help in general about Regular Expressions:
Regular-Expressions.info - The Premier website about Regular Expressions
Boost.Regex Perl Regular Expression Syntax and the format string
Regular Expression HOWTO A.M. Kuchling
Perl Regular Expression Tutorial
A nice one sheet overview about the syntax (PDF file)
http://etext.lib.virginia.edu/services/ … regex.html
http://regular-expressions.info/reference.html
http://www.regxlib.com/Default.aspx
blogging community devoted to the topic of regular expressions
dead ==> Starmerj's Perl RegExp Crib Sheet
PDF: RegEx QuickSheet
Something in german:
Reguläre Ausdrücke in The Bat!     auf Deutsch
nicht wissenschaftlicher Workshop für Regular Expressions
Online test:
Excellent RegEx evaluator, useful for RegEx's that'll run in JavaScript.
An very minimalist online Ajax-based ASP.NET site
#3 2008-09-16 08:53
admsupport
Hi back Stefan,
I installed ReNamer last night among few others apps to make a choice. I tried them in blind with few basic rules. I kept ReNamer, I am now reading the forum.
The other file renamers had a the similar pattern: rename file using the replace rule, from: empty, with: new file name. Renamer was a bit different and I was worry to make an uncessary step with a delete rule beforhand.
It does, of course wink
I will read your posts with interest and take a look at a RegEx tutorial link I found elsewere on the forum. However RegEx, programing & scrpting are beyond my qualifications. Even with simple operation, I will need some help on the forum, I am afraid.
So, thanks for the support.
