#1 2008-10-17 11:22
VolgensBartjes.nl
Adding upcounting numbers when duplicate names expected?
first of all, i really like the renamer! i only have one case, which i cannot solve. i hope it is possible with some help:
i have a bulk of images with the following names (just a few as explanation):
i can set the renamer so that the result is an name of the first 5 characters and the extention. but, sometimes there are 2 or 3 images of one numer, which has diferent names in the original names. what i would like is to give them an number if duplicate names would be expected. is that possible? so the result i would like is the folowing:
or if its not possible to only add an numer to the second duplicate, it could maybe be something like this:
i hope someone could tell me if theres a way to do something like this...
much thanks,
Bart
#2 2008-10-17 12:47
Re: Adding upcounting numbers when duplicate names expected?
Hi Bart and welcome to the forum wink
Please try an PascalScript as last rule.
There is an script in your ReNamer install folder which do the trick I think ...
1.) add your rules as before
2.) add Rule PascalScript
___ 3.) click down right on [Scripts]
_______4.) choose "Serialize duplicates"
Click on Preview to see if it work.
#3 2008-10-17 12:52
VolgensBartjes.nl
YES!
it works! thanks. i just edited the script so that he does not add ( and ) to it, so now its perfect.... thanks.
#4 2010-05-07 12:49
airjrdn
Awesome little trick.  This has to be the best renaming app out there!
#5 2010-05-07 14:24
BTW, FYI, here is an another way do to this >> http://www.den4b.com/forum/viewtopic.php?id=869
Have a look at the Options menu (above files table),
there you'll find an option called "Fix confilcting new names"
