#1 2008-11-21 11:57
ulysserevient
Filters masks
Is it possible to select all files except files containing the string xyz ?
#2 2008-11-22 03:07
Re: Filters masks
Hi ulysserevient and welcome,
ulysserevient wrote:
Try
1.) "Select by mask"  (Ctrl+M) ==> *xyz*.*
2.) "Invert Selection" (Ctrl+I)
Just right click on the file list for an context menu with far more options. (I think you look for 'Mark' instead of 'Select' ? )
150
#3 2008-11-22 19:06
Sunshy
Re: Filters masks
This is great, I was doing this in windows and now I can do everything within Renamer. Thanks.
