#1 2008-12-24 11:33
FairwayKnight
Comment field in rules section
Have a suggestion for something I dearly miss:
Could you put in a comment field (column) after the rules field or statement field.
Since I normally work with a set of about 30, sometimes quite hefty reg exps, rules.
But after I didnt look at them for some weeks I need some reminders connected to the rules helping me remember what I intendend the rule for. A comment field would be very welcome.
#2 2008-12-24 16:44
Re: Comment field in rules section
Hello FairwayKnight and welcome to the community,
you may find this thread useful as an answer:
http://www.den4b.com/forum/viewtopic.php?id=386
http://www.den4b.com/forum/viewtopic.php?id=379
HTH?
Note: this thread here is redundant and could be deleted by mod
#3 2014-05-29 11:38
Elektro
Sorry, I never imagined that someone had published the same peculiar suggestion.
Thanks for answer
#4 2014-06-04 15:56
This feature is on the list for consideration, but it's on the lowest priority at the moment.
#5 2018-06-24 23:54
Rule comments have been implemented in ReNamer 6.8.0.4 Beta.
- You can add/edit rule comments via the rules context menu, or using a Shift+Enter hotkey.
- Comments are displayed in the Statement column, replacing the auto-generated rule description, when available.
