#1 2009-01-04 12:19
CeeJay
Delete until the first digit
Hi - happy new year,
Is it possible to do a remove rul - that removes all letters until it meets the first digit,
example:
aklsdjask1test.doc   should be renamed to 1test.doc
ahs1topic.xls  should be renamed to 1topic.xls
3years.doc should be 3years.doc.
is this possible???
CJ
#2 2009-01-05 17:58
Re: Delete until the first digit
Should be possible with RegEx. I'm sure someone much more well-versed in the subject than me will tell you how. smile
#3 2009-01-05 17:59
Try with the RegEx rules:
Expresion: ^(\w*?)(\d)
Replace:    $2
#4 2009-01-05 19:17
eR@SeR
As I'm not experienced well enough with RegEx I tried modifying these ones Renamer:Remove track numbers but failed sad
Your RegEx do the work (nice one smile) and I'll just submit this modified one as it removes any non digit from start of line, till first digit. Someone will need it perhaps.
Expression: ^(\D*?)(\d)
Replace: $2
I used \A instead ^ too, and it seems that's the same. Is it? Same question is for \Z and $...
It will be good if it could be something like "RegExes" button, similar like Scripts in PascalScript rule, or pop up window like in Insert and Replace rules (Meta Tags), so every user can use already "served" regular expressions. Newly created will be updated etc. Sorry for posting it here, but as we speak about it... roll
P.S. I'll submit mine RegEx in ReNamer: Examples of Regular Expressions. I'll recommend you to do too, for future reference. Thanks wink
#5 2009-01-05 23:20
CeeJay
Thanks for your help:
eR@SeR's solution did the trick for me....
Cheers,
Carsten
#6 2009-01-07 21:50
krtek
Yup, they're complete sinonims... smile
