Hi. First of all... congratulations on you applications! Its faboulus. And its free. That means you deserve many many thanks!
Now, to the suggestion. In serialization, this would be a good option : To reset the counter when the loop comes to a new folder (when using subfolders).
Example:
Folder (DIR) D1 has two files and three subfolders. Each subfolders have some files.
D1-F1,F2
D2-F3,F4
D3-F5,F6
D4-F7,F8
When we run serialization and with three digits, the result would be:
D1-001,002
D2-001,002
D3-001,002
D4-001,002
What do you think? Could this work?
Thanks in advance and keep up the good, honest work!
Greetings from Slovenia
