#1 2009-01-28 02:17
LuisLlamas
Suggestion for rename extension
I think it could be interesting the idea of change the "skip extension" check box, for two checkbox with "apply to extension" and "apply to name", so you can choose if you want to apply the rules to the name, the extension, or both of them.
Apologize for my terrible english!
#2 2009-01-28 02:48
Re: Suggestion for rename extension
#3 2009-01-28 12:25
LuisLlamas
Yes, I see. You made the same suggestion in this post. Sorry for that, I didn't found it before.
Well, If i have the same idea, it should be an important new feature for ReNamer
#4 2009-01-28 17:07
Oh, I agree completely! That's why I went to the extent of making mock-ups in a graphics program of what the UI should look like. smile But try as I might, the suggestions were rejected and so I let it be. You can certainly try, but I guess unless enough people turn up clamouring for this feature, things are not going to change.
