#1 2009-02-04 09:54
Markboynz
Multiple variables carry through
Hi there,
I'm sure this is very simple, but I am failing entirely to work it out.
I am trying to rename files that have a standard numbering system, which is s##e## where # could be any number. I want to replace those with ##x##. To make life trickier, I would ideally like to drop any preceding 0s from the first set of numbers, but keep them if they are in the second set.
Thus:
s01e01 becomes 1x01.
s01e12 becomes 1x12.
s12e12 becomes 12x12.
And just to clarify, these numbers may have other text before/after which needs to remain intact.
Any help would be gratefully appreciated!
#2 2009-02-04 10:51
Re: Multiple variables carry through
I suppose you mean "where # could be any digit"?
Now I'm not a RegEx guru by any stretch of the imagination wink, but I suppose the following RegEx rule should work (though there might be better ways of doing the same as well):
Expression: s0?(\d?\d)e(\d{2})
Replace: $1x$2
#3 2009-02-04 12:18
Almost perfect, Andrew! wink
Here is a slightly improved RegEx, which will handle number sequences of any length:
Expression: s0*(\d+)e(\d+)
Replace: $1x$2
