Since currently Renamer does not provide serialized letters yet, here is at least a partial solution. It relies on UserInput and provides the letters a..z, then aa..az, ba..bz,..., za..zz. Sorry, not more than 702 names.
Usage: UserInput | Options | Load from text file
If you use naming from a to zz frequently but not always, creating the rule afresh each time would be inconvenient and time consuming. Add Files changes the directory also of UserInput | Options | Load from text file. Therefore enable "Save rules configuration on exit, load on startup.", add the UserInput rule, always keep it, and just activate / deactivate it.
Adding letters starting from a different first letter requires to edit the rule and delete those letters before. If one stores the default rule, one should clone it, activate the clone, and edit only the clone.
Although this is by far not the easiest solution, it may be an alternative to using a second file numbering and renaming software just for the purpose of adding serialized letters as a suffix to, say, a constant file number as a prefix.
So maybe my sample reference file saves someone some work. The Pascal experts might have different suggestions, I'd guess. In the meantime, I continue to hope for serialized letters.
Copy the following and save it as a file with the name a_zz.txt in, e.g., the Renamer program directory. (I have proofread the list for typos once.)
a
b
c
d
e
f
g
h
i
j
k
l
m
n
o
p
q
r
s
t
u
v
w
x
y
z
aa
ab
ac
ad
ae
af
ag
ah
ai
aj
ak
al
am
an
ao
ap
aq
ar
as
at
au
av
aw
ax
ay
az
ba
bb
bc
bd
be
bf
bg
bh
bi
bj
bk
bl
bm
bn
bo
bp
bq
br
bs
bt
bu
bv
bw
bx
by
bz
ca
cb
cc
cd
ce
cf
cg
ch
ci
cj
ck
cl
cm
cn
co
cp
cq
cr
cs
ct
cu
cv
cw
cx
cy
cz
da
db
dc
dd
de
df
dg
dh
di
dj
dk
dl
dm
dn
do
dp
dq
dr
ds
dt
du
dv
dw
dx
dy
dz
ea
eb
ec
ed
ee
ef
eg
eh
ei
ej
ek
el
em
en
eo
ep
eq
er
es
et
eu
ev
ew
ex
ey
ez
fa
fb
fc
fd
fe
ff
fg
fh
fi
fj
fk
fl
fm
fn
fo
fp
fq
fr
fs
ft
fu
fv
fw
fx
fy
fz
ga
gb
gc
gd
ge
gf
gg
gh
gi
gj
gk
gl
gm
gn
go
gp
gq
gr
gs
gt
gu
gv
gw
gx
gy
gz
ha
hb
hc
hd
he
hf
hg
hh
hi
hj
hk
hl
hm
hn
ho
hp
hq
hr
hs
ht
hu
hv
hw
hx
hy
hz
ia
ib
ic
id
ie
if
ig
ih
ii
ij
ik
il
im
in
io
ip
iq
ir
is
it
iu
iv
iw
ix
iy
iz
ja
jb
jc
jd
je
jf
jg
jh
ji
jj
jk
jl
jm
jn
jo
jp
jq
jr
js
jt
ju
jv
jw
jx
jy
jz
ka
kb
kc
kd
ke
kf
kg
kh
ki
kj
kk
kl
km
kn
ko
kp
kq
kr
ks
kt
ku
kv
kw
kx
ky
kz
la
lb
lc
ld
le
lf
lg
lh
li
lj
lk
ll
lm
ln
lo
lp
lq
lr
ls
lt
lu
lv
lw
lx
ly
lz
ma
mb
mc
md
me
mf
mg
mh
mi
mj
mk
ml
mm
mn
mo
mp
mq
mr
ms
mt
mu
mv
mw
mx
my
mz
na
nb
nc
nd
ne
nf
ng
nh
ni
nj
nk
nl
nm
nn
no
np
nq
nr
ns
nt
nu
nv
nw
nx
ny
nz
oa
ob
oc
od
oe
of
og
oh
oi
oj
ok
ol
om
on
oo
op
oq
or
os
ot
ou
ov
ow
ox
oy
oz
pa
pb
pc
pd
pe
pf
pg
ph
pi
pj
pk
pl
pm
pn
po
pp
pq
pr
ps
pt
pu
pv
pw
px
py
pz
qa
qb
qc
qd
qe
qf
qg
qh
qi
qj
qk
ql
qm
qn
qo
qp
qq
qr
qs
qt
qu
qv
qw
qx
qy
qz
ra
rb
rc
rd
re
rf
rg
rh
ri
rj
rk
rl
rm
rn
ro
rp
rq
rr
rs
rt
ru
rv
rw
rx
ry
rz
sa
sb
sc
sd
se
sf
sg
sh
si
sj
sk
sl
sm
sn
so
sp
sq
sr
ss
st
su
sv
sw
sx
sy
sz
ta
tb
tc
td
te
tf
tg
th
ti
tj
tk
tl
tm
tn
to
tp
tq
tr
ts
tt
tu
tv
tw
tx
ty
tz
ua
ub
uc
ud
ue
uf
ug
uh
ui
uj
uk
ul
um
un
uo
up
uq
ur
us
ut
uu
uv
uw
ux
uy
uz
va
vb
vc
vd
ve
vf
vg
vh
vi
vj
vk
vl
vm
vn
vo
vp
vq
vr
vs
vt
vu
vv
vw
vx
vy
vz
wa
wb
wc
wd
we
wf
wg
wh
wi
wj
wk
wl
wm
wn
wo
wp
wq
wr
ws
wt
wu
wv
ww
wx
wy
wz
xa
xb
xc
xd
xe
xf
xg
xh
xi
xj
xk
xl
xm
xn
xo
xp
xq
xr
xs
xt
xu
xv
xw
xx
xy
xz
ya
yb
yc
yd
ye
yf
yg
yh
yi
yj
yk
yl
ym
yn
yo
yp
yq
yr
ys
yt
yu
yv
yw
yx
yy
yz
za
zb
zc
zd
ze
zf
zg
zh
zi
zj
zk
zl
zm
zn
zo
zp
zq
zr
zs
zt
zu
zv
zw
zx
zy
zz
Thanks for the list! I too would like alphabetic serialisation in ReNamer, but till then, this will have to do.
BTW, how did you create the list? Did you type in all 702 lines manually?
Here's a little help for people who want to create a list of arbitrary length:
Start MS Excel.
In the first cell, enter this formula exactly:
=CHAR(MOD(ROWS($1:1)-1,26)+97)
to get the letter a.
Move the mouse to the bottom right corner of the cell till it becomes a + (plus), then left click and drag the mouse down.
Release to fill in the rest of the letters automatically, i.e. b, c, ..., z, a, b, ... and so on.
Use the following formula exactly:
=CHAR(INT((ROWS($1:1)-1)/26)+97)&CHAR(MOD(ROWS($1:1)-1,26)+97)
to get the series aa, ab, ac, ..., az, ba, bb, ..., bz, ... and so on.
To edit the formula of any cell, either select it and press F2, or else double-click it.
To get capital letters instead of small, change the number 97 in any formula to 65. So for example to get A, B, ..., Z, A, B, ... and so on, change the formula above from:
to
=CHAR(MOD(ROWS($1:1)-1,26)+65)
This technique should prevent mistakes and save loads of time, as you can be sure of no errors/duplicates and so no need to proof-read.
Well, almost did I type 702 manually. The only trick was to copy and paste ab..z and then insert the current first letter each time by pressing down key, left key, and typing that letter... Yes, nasty work it was :)
I had expected that there must be automatic ways of typing but I figured that I would need more time to find out than to type 702 lines. Thank you anyway, although I use OpenOffice rather than Excel.
I've been fiddling on my own for this issue (not that I really need it, but it's an exercise in PascalScript), I came up with something that may be close to what you're looking for. It's probably closer to the original spirit you wanted your alphanumeric serialize to be, but here it is anyway.
LETTERS = 'abcdefghijklmnopqrstuvwxyz';
NUMBERS = '0123456789';
BOTH = '0123456789abcdefghijklmnopqrstuvwxyz';
ALPHA_FORMAT = 'ln';
function AlphaSerialize(const i: Integer; const structure: String): String;
single: Char;
letterset: String;
format_char: Char;
format_r: String;
if (length(structure) > 0) then
format_char := structure[length(structure)]
else
if (i = 0) then
result := '';
exit
end
else
result := inttostr(i);
exit
end
if (format_char = 'l') then
letterset := LETTERS
else
if (format_char = 'b') then
letterset := BOTH
else
letterset := NUMBERS
single := letterset[(i mod length(letterset)) + 1];
format_r := copy(structure, 1, length(structure) - 1);
result := AlphaSerialize(i div length(letterset), format_r) + single;
Initialized: boolean;
I: Integer;
if not Initialized then
I := 1;
Initialized := True;
FileName := FileName + AlphaSerialize(I, ALPHA_FORMAT);
I := I + 1
Here, you define a format string for the alphanumeric serialization you want... 'l' for letters (that's a letter L), 'n' for numbers, and 'b' for both. And if you have serialization which extends longer than the format string specifies... well, you get numbers out front, though I suppose a few tweaks, you could change that to letters to match what you accomplished with your a_zz.txt
Nice script! You're a very good programmer prologician.
BTW, the letters are tacked on after the extension. Ignoring the extension might be preferred, in which case this line should work:
FileName := WideExtractBaseName(FileName) + AlphaSerialize(I, ALPHA_FORMAT) + WideExtractFileExt(FileName);
Also, if I specify ALPHA_FORMAT as 'll', it starts from 'ab' rather than 'aa'. Can you correct that?
Hehe, so you caught me with some degree of laziness. Oh, well.
The second point was the setting of the initial value... so, switched it to 0 instead of 1, and that should do it.
The new version:
ALPHA_FORMAT = 'll';
single: Char;
letterset: String;
format_char: Char;
format_r: String;
else
if (i = 0) then
result := '';
exit
end
else
exit
end
else
letterset := BOTH
else
I: Integer;
I := 0;
I := I + 1
And... tankoo for the compliment.
Hmmm...
Someone was firs... Nice job Prologician
Mine version is simpler... It only goes throug letters without padding... But I'll post it anyway. Just as an exercize.
i, k,p: Integer;
Letters : string;
Pad: Array[1..100] of Integer;
Initialized: Boolean;
Serialization : String;
function CheckZ(p: Integer): Boolean;
if Pad[p] >= Length(Letters) then
Pad[p]:=1;
if p > 1 then
Pad[p-1]:=Pad[p-1]+1;
CheckZ(p-1);
end
else
result := True;
Letters := 'abcdefghijklmnopqrstuvwxyz';
i := 1;
p := 1;
if i > Length(Letters) then
i:=1;
if CheckZ(p) = true then p:=p+1;
Pad[p]:=i;
Serialization:='';
for k:=1 to p do
Serialization:=Serialization + Letters[Pad[k]];
FileName := WideStripExtension(FileName) + Serialization + WideExtractFileExt(FileName);
i := i + 1;
Nice krtek! So this goes from a-z, aa-az, ba-bz, ..., za-zz, then to zza and so on?
I tested krtek's script with an abbreviated alphabet (basically just the letters 'a' through 'e'), and I see two things. First, it looks like the script only handles up to two letters at the moment. Additionally, it doesn't go through the final letter when it's the leading letter (that is, when it hits 'de' using my abbreviated alphabet, it is followed by 'aa' again instead of 'ea').
A quick and dirty test of prologician's second script lets it appear pretty useful, thank you! The constants at the top can be changed easily. Further constants might be introduced and then treated in the if...else section.
