#1 2009-04-27 13:27
parisphoto
Sequentially Numbering Folders?
I have a master folder labeled FOLDERS. This folder contains 1oo Sub Folders labeled New Folder (1), New Folder (2), etc.
I want to rename all these subfolders so they are named 1, 2, 3, 4, etc. up to 100.
I just can not figure out how to accomplish this. Any and all help would be greatly appreciated. Thanks.
#2 2009-04-27 15:29
eR@SeR
Re: Sequentially Numbering Folders?
Hi and welcome wink
Here are the steps for your example:
1) In filter settings, tick only "Add folders as files" to process only folders
2) Add "Delete rule"
Until: till the end, [x] skip extension
3) Add "Serialize rule"
Incremental: index starts and step are 1
Insert where: you can tick prefix, suffix or position radio button, [x] skip extension
4) Select all (Ctrl+A) of your New Folders and Drag & Drop to files table
5) If not sorted, sort by name by clicking on "Name" column.
6) Click Preview to see if everything is as you wish, then click Rename button and that's it.
For more information of using ReNamer you can check the User Manual (Alt+F1) or unofficial one created by Narayan which is solid.
Cheers wink
#3 2009-04-27 17:03
krtek
Or use Regex rule:
Expression: "New folder \((\d+)\)"
Replace: $1
