Hi, I am writing to request your help to solve this problem.
Have a folder which inside has 1000 folders, each one with a pdf file, so the path of the files and folders looks like this:
bigfolder/folder1/file1.pdf
bigfolder/folder2/file2.pdf
bigfolder/folder3/file3.pdf
bigfolder/folder4/file4.pdf
where folder#is a set of 10 characters and file# has 8 characters.
I would like to "extract" each file from its folder, rename it with the name of the folder and place the whole in the big folder, so the final path of the files should be:
bigfolder/folder1.pdf
bigfolder/folder2.pdf
bigfolder/folder3.pdf
bigfolder/folder4.pdf
The empty folders will be then removed manually.
Could anybody please illustrate how to do this with the ReNamer?
Thanks a lot in advance!!!
If you have just one file per folder you can do it that way:
1. Delete rule:
From position 1, till the end, skip extention
2. Insert rule:
What: Full_path_to_bigfolder\:File_FolderName:
as Prefix
The path needs to start from drive name and end with "\", eg. d:\bigfolder\
:File_FolderName: - is a MetaTag which you can type as above or select from Insert-MetaTag dialog
Voila!
Thanks for this very useful tip!!!
