Assume I want to cut the 5 first chars of a filename and insert them on the 4th last position of a filename (including extension).
How can I do this with Renamer?
Example
aaaaa_foobar.log
bbbbb_blah.log
should be after renaming:
_foobaraaaaa.log
_blahbbbbb.log
With RegEx: (this is for 5 characters)
Expression: ^(.{5})(.+)$
Replace:     $2$1
and mark skip extension
