Currently, you are saving Presets to a location that requires Admin or Power-User privileges ... Users therefore cannot use this feature.
By allowing the user to specify the default location for saving presets, the user can choose a path to which he is permitted. Your app would then read from there as well, for the Import feature.
Thanks for considering it.
Extensive discussions have taken place previously here:
http://www.den4b.com/forum/viewtopic.php?pid=2929#p2929
and here:
http://www.den4b.com/forum/viewtopic.php?id=434
AFAIK, Denis hasn't implemented this feature yet, but it's there on his To Do list.
