#1 2009-08-10 19:14
Parador
Command line and 5000 files validation limit
I'm using ReNamer from the command line to on a daily schedule to rename picture files....
Everything works great.... till a very large amount of files is to be renamed...
I think it happens for more than 5000 files, that renamer asks back if im sure I want to rename/validate them...
is there a possibility to switch that off?  The hole process stops and needs a human hand to continue...
Thanks for your help in advance
#2 2009-08-11 00:54
Re: Command line and 5000 files validation limit
That is correct, 5000 files is the limit for the validation warning...
I have decided to disable this warning in the command line renaming mode. You can try it in the latest dev version: ReNamerBeta.zip
#3 2009-08-11 05:51
Parador
Thanks alot for that lightning fast help!
