#1 2009-08-24 14:40
krtek
Append preset icon text
Hard to name it a bug.
The Append preset icon in the Preset Manager has the same text as Load preset, which is "Load Preset (Enter)".
#2 2009-08-29 20:40
Re: Append preset icon text
I copied the "Add Preset" button to create "Append Preset", but forgot to change the hint text. It is fixed now.
Thanks.
