#1 2009-08-26 14:32
krtek
Strange behaviour of the CleanUp rule in the Analyze window
It happens only in Analyze window as it is impossible (at least for me) to make a file with spaces at the beginning or after the extention. Windows strips them out.
If you have a filename (or few filenames) in Analyze window (with Apply rules for each line on)
that have a space or spaces at the end (after the extention), eg.:
"file  .txt   "
" file  .odt  "
"file.exe  "
and you apply the CleanUp rule to them (just fixing spaces with skip extention),
then the last filename have it's spaces stripped out, so you get:
"file.txt  "
"file.odt   "
"file.exe"
#2 2009-08-29 20:44
Re: Strange behaviour of the CleanUp rule in the Analyze window
I used TrimRight() function for the output to remove trailing empty line which was created by the component. This also removed all trailing spaces. Obviously, at the time of development i didn't consider a scenario where user would want/use trailing spaces.
Anyway, I have fixed it now. Only trailing new lines will be removed, trailing spaces will be left intact.
#3 2009-08-29 21:26
krtek
If not testing narayan's assumptions in the manual, I would never get on this  wink
