#1 2006-04-23 23:50
jarin_b
ReNamer: "Presets/Save As" - don't work
I found little bug: "Presets/Save As" don't work when folder "Presets" don't exist.
I use ReNamer 3.05
Regards,
Jarek
PS: Excuse my "english"
#2 2006-04-24 09:52
Re: ReNamer: "Presets/Save As" - don't work
Hi Jarek,
You've discovered a little bug - I've accidentally removed the code for checking if the Presets folder exists (occurs from v3.00). Thanks for a workaround for Jerry!
I've fixed it now, you can download the latest dev version: ReNamerBeta.zip
Later today I should release a new version of ReNamer smile
