#1 2009-10-14 13:59
eR@SeR
Autosize table on change
I've found a problem in files table, when removing longer filenames it should autosize to the next most longest filename. When you add files then it work properly. Here are images to look better:
Settings/Preview: [x] Autosize table on change (is checked)
#2 2009-10-14 20:17
Re: Autosize table on change
Ok, now I see what you were talking about...
It is not a bug, it is the intended behavior. The wording of the option "Autosize table on change" should probably say "Autosize table when files are added or updated, but not when removed" wink
I made it work this way because I thought that resizing the table when files are removed might not be worth the overhead associated with autosizing of table.
Well, I guess priorities change over time. It seems that user satisfaction is more important then the overhead in this case, so I made table autosize when files are removed as well.
ReNamerBeta.zip
#3 2009-10-14 21:35
eR@SeR
Oh, it was intended behavior yikes
Anyway thanks for the change. Works perfect! wink cool
