#1 2005-04-04 01:00
ReNamer 1.61, got even better!
Big update this time, some new features...
Hopefully, next major update will radically change the functionality of the program.
Idea is to implement MP3 files renaming based on their ID3 tags!
ReNamer 1.61
* added files up/down moving feature: Ctrl + Up/Down Arrow;
* added Brackets rule: to strip out contents of the brackets;
* expanded sorting options: sort numerically, by time created, by last modified time, by path/name;
* added Validate button, for validation at any time;
* small improvements to the files table;
* added some hints for the buttons;
* new filenames are always trimmed on both sides;
* added ascending/descending Sorting, based on filename;
* ability to load new filenames from the text file;
* table columns are auto-sized automatically whenever new files are added as well as after filenames generation;
* improved filenames validation: warnings are given when two or more files have the same generated name, or if at least one filename is an invalid Windows filename or filename is an empty string;
