#1 2010-01-06 14:34
Command Line (/rename) vs. Auto-Preview??
I work with "Auto preview when new files are added"
And I was trying the "Create Links" feature to rename directly with a preset that includes a pascal with WideInputBox.
And I found that is asking twice for the name.
I think it’s because of the auto-preview
wink
#2 2010-01-23 15:45
Re: Command Line (/rename) vs. Auto-Preview??
Yes, that is exactly what was happening. Now, all of the auto previewing options are disarmed for the command line renaming mode. You can try the latest development version.
Thanks for reporting! smile
#3 2010-05-06 18:10
Oh, damn I didn't see this reply...
Well, the previous bug is solved.  big_smile
But I came back to this thread because I think there is the same problem for the Analyze window  when "Auto preview when new files are added"(Setting)  and "Automatically apply rules"(Option in the window) are both enabled.
(The problem is the same a pascal dialog asking twice for the input)
#4 2010-05-20 23:54
Symptoms are the same, but circumstances are really different, sounds like a new topic was needed.
Anyway, it should be fixed now. Try latest dev version.
#5 2010-05-21 20:19
Sorry about that.
Yes it's fixed tongue, Thanks.
