#1 2010-01-13 21:20
prologician
Compare CRC with filename
I think the topic line really says it all here. I often have files with CRCs written into the filename (something like "File blah blah [AAAABBBB].zip"). I have a specialized tool which does the job (well, kinda. It seems that my virus scanner decided to eat it....), which calculates a file's CRC, verifies that the CRC in the filename matches the file's calculated CRC, and also gives the option to insert the calculated CRC into the filename.
The latter part I can do with some simple stuff in Renamer. But as for the filename-comparison part, I think that would be a particularly handy feature in Hasher.
#2 2010-03-23 19:42
Re: Compare CRC with filename
Very interesting suggestion! I think you will see it in Hasher once the new version will be released.
