hallo!!!
I have my mp3 files in folders like
d:\MP3\Rock\ArtistName\AlbumName\01 - filename.mp3
and I want to rename them to
d:\MP3\Rock\ArtistName\AlbumName\ArtistName - 01 - filename.mp3
can you help me?
thank you...
hallo!
One of the solution would be:
1st cut/move your files to ArtistName folder and use this rule
1) Insert: Insert ":File_FolderName: - " as Prefix
using metatags...and then move back renamed files to AlbumName folder. HTH?
d:\MP3\Rock\ArtistName\AlbumName\ArtistName - 01 - file.mp3
I hope that you typed wrong underlined word; should be filename?
Cheers
thank you for your answer but it isnt easy for me to cut/move my files to ArtistName folder because I have to do it too many times.
So i was hoping for a pascal script or something that could do the renaming in all my files automatically...
ps. you are right for the file=filename
I would do this:
Rule 1: PascalScript.
begin FileName:=FilePath; end.
Rule 2: RegEx.
Expression: ([^\\]+)(\\[^\\]+\\)([^\\]+)$
Replace: $1$2$1 - $3
I would do it in that way, but in your case where you have a lot of folders/files, pascal script can do the job. I hope that SafetyCar's solution is right for you?
Or an another approach.
For exactly such issues Denis has invented the new Rearrange Rule.
Read the wiki ==> http://www.den4b.com/wiki/ReNamer:Rules:Rearrange
But you need to download and use one of the latest betas
==> http://www.den4b.com/projects/ReNamer/ReNamerBeta.zip
Just unpack and use this one, or copy the ReNamer.exe into your ReNamer install folder.
Please test this with some test files first.
Add the following 4 rules. (see wiki about rules http://www.den4b.com/wiki/ReNamer:Rules)
0)
Name: d:\MP3\Rock\ArtistName\AlbumName\01 - filename.mp3
1) Delete: Delete from Position 1 until the End (don't skip extension) (this deletes the old file name)
New Name:
2) Insert: Insert Metatag ":File_FilePath:" as Prefix
New Name: d:\MP3\Rock\ArtistName\AlbumName\01 - filename.mp3
3) Remove: Remove all "d:\" (skip extension)
New Name: MP3\Rock\ArtistName\AlbumName\01 - filename.mp3
4) Rearrange: Split by delimiters "\", New pattern "$3 - $5" (skip extension)
New Name: ArtistName - 01 - filename.mp3
Rearrange Explanation:
$1 \ $2 \ $3 \ $4 \ $5
Once you have added all 4 rules,
press on preview
and you should see
Name New Name
01 - filename.mp3 ArtistName - 01 - filename.mp3
If this all went fine, press on Rename.
Now test this with one folder of your real files, then with the rest.
HTH?
i tried SafetyCar's way and i had the result i was hoping for...
thank you SafetyCar ...
I will try Stefan's suggestion too, but I want to study it first..
many thanks to all of you..
