and
What is that delete rule for anyway?
"my_music_track" = 14 chars. So the rule deleted from the "_" at position 15 till the first instance of "2" (leaving "2" behind), which after 3019, can be found in 3020, 3021, 3022 etc. So _3020, _3021 etc. became 20, 21 and so on. In your first screenshot too if you see, the "_" after "track" and before 2993, 2994 etc. has disappeared due to the same rule.
Got it?
Understand. Thank you ![]()
If what you want is create a whole new name, why don't you just delete it before you start building the new one? ![]()
SafetyCar And how it to make through a program?
By the way, as it is possible to rename files here so "my_music_track _" with the counter without "artefacts"
1. This as first rule:
Delete Rule
Until: Till the end
(mark "skip extension")
2. No, there is no easier way to do the serialization
A pity. Thanks for your help ![]()
