#1 2010-04-23 15:25
mamyllyn
Drag and drop - without reordering the files
Is there some way to disable the auto-ordering in program, when dropping new files?
Example: I have tracks numbered right in Id-tags, and I am sorting them right berofe drop. After dragging to the program, it re-orders my files...
Thanx for help!
#2 2010-04-23 16:02
Re: Drag and drop - without reordering the files
Right click over the column title, and the last option is "Cancel Sorting". (Do it before dragging)
#3 2010-04-23 16:03
mamyllyn
Thanx...I was quite monkey. I tried that after the adding of files ;-)
