Is there any way to assign variables on a pascal rule and read it from other pascal rule???
1) First Script to Store one var:
FileWriteContent('C:\Temp\var.txt', 'string or digit to store');
2) Second Script to Read one var:
variable: string;
variable := FileReadContent('C:\Temp\var.txt');
showmessage('Stored var content: ' + variable);
Or store an whole list of information, one per line:
First Script to Store many vars:
FileAppendContent('C:\Temp\myVars.txt', FileName + #13#10);
Second Script to Read one var of many:
variable := FileReadLine('C:\Temp\myVars.txt', 3);
variable: string;
index: integer;
if (index < 1) then index := 1;
variable := FileReadLine('C:\Temp\myVars.txt', index);
showmessage('Stored var content of index( ' + IntToStr(index) + '): ' + variable);
index := index + 1;
I was thinking on something easier, but thanks for this solution.
