#1 2010-06-11 01:36
JohnnySH
Swap file name
Hi
I have my file names as so
Artist - Title
I would like to swap artist with title, like so.
Title - Artist
Is there any easy way to use renamer to swap content before and after my "-" in the file name
thanks
#2 2010-06-11 02:52
eR@SeR
Re: Swap file name
Hi, it's possible. Use RegEx rule:
Expression: "(\w+) - (\w+)"
Replace: "$2 - $1"
Look at ReNamer: Examples of Regular Expressions topic for more info about RegEx...
or
Rearrange rule (beta version):
1) Rearrange: Split using delimiters "-", New pattern "$2 - $1" (skip extension)
2) CleanUp: Fix spaces (skip extension)
Without 2nd rule we have " Title - Artist ". Is it possible to have "Title - Artist" somehow?
#3 2010-06-11 03:28
JohnnySH
Re: Swap file name
Thank you so much
all worked fine
well done for such a great program
#4 2010-06-11 12:48
Re: Swap file name
Use " - " as a delimter (with spaces around the dash), then you won't need to use cleanup rule.
Also, it is safer to use "exact pattern of delimiters" option, in case the filename is like "Title - Artist - Album" so the last part will remain in the filename as opposed to be truncated if "delimiters" option is used.
#5 2010-06-11 18:07
eR@SeR
Re: Swap file name
Great, thanks smile
...in case the filename is like "Title - Artist - Album"...
@JohnnySH
If you want that Album (or whatever) remain on 3rd position use this:
1) Rearrange: Split by delimiters " - ", New pattern "$2 - $1 - $3" (skip extension)
Title - Artist - Album --> Artist - Title - Album
#6 2010-06-11 20:26
Re: Swap file name
eR@SeR, you might have missed the point of "exact pattern of delimiters" option.
What if filename contains 3 or 4 or 5 or even 10 dashes? When using "delimiters" there is always a possibility of loosing parts of the filename and that's why we made "exact pattern of delimiters" option. Try it with filenames which contain many dashes in the name and you'll see what I'm talking about.
P.S. Maybe this should be added to Wiki as a warning note.
#7 2010-06-12 02:58
eR@SeR
Re: Swap file name
I know what you've talked about. First I used:
1) Rearrange: Split by exact pattern of delimiters " - ", New pattern "$2 - $1 - $3" (skip extension)
and get from "Title - Artist - Album" ---> "Artist - Album - Title - "    not desired
then
"Title - Artist - Album" --> "Artist - Title - Album" desired
1) Rearrange: Split by exact pattern of delimiters " - ", New pattern "$2 - $1$3" (skip extension)
"Title - Artist - Album" ---> "Artist - Album - Title" not desired (Album is on 2nd place)
Only because of results I used "delimiters" instead "exact pattern of delimiters".
How to get desired result using "exact pattern of delimiters"...and also if we have 4 or 5 words for ex. "Artist - Title - Album - Year - Genre" to swap first three words (combination is irrelevant) but other two to be intact. Sorry I don't get these things very well sad
That explanation could be added to Wiki Rearrange_Examples as warning note too.
Thanks in advance wink
#8 2010-06-12 16:10
Re: Swap file name
With "exact pattern of delimiters" you basically define how many parts you want the filename to be split into. If you specify 1 delimiter that you end up with exactly 2 parts, if you specify 2 delimiters then 3 parts, and so on.
> Rearrange: Split by exact pattern of delimiters " - ", " - ", New pattern "$2 - $1 - $3" (skip extension)
Input: Title - Artist - Album
Output: Artist - Title - Album
