#1 2010-07-01 21:10
Foreverlad
Removing Various Content Within Brackets
First off, let me say THANK YOU for this amazing program.  Renamer has been a lifesaver in converting and adjusting my mega music collection.
I've done some searching through this site and the wiki, but I was unable to find anything definitive that I could actually understand lol.
I have a number of files with dates and years in the file name, all bracketed.  If I had it my way, the brackets and everything inbetween them would be removed.
Example:
Den4b Anthem [July 2010].mp3  ------>   Den4b Anthem.mp3
I know how to remove brackets, or a particular phrase/word, but is there a (fairly) simple way to remove various words, phrases, dates or numbers sandwiched between brackets?  Basically, can Renamer recognize brackets, parentheses or some other symbol as a container, and remove everything within that container?
Any help would be greatly appreciated.
#2 2010-07-01 21:24
Re: Removing Various Content Within Brackets
Hi Foreverlad, welcome.
Can you please try if an "CleanUp"-rule with "Strip out content of brackets" work for you?
Don't forget to check "Fix spaces" too.
See http://www.den4b.com/screenshots.php?pr … reenshot=7
#3 2010-07-01 21:52
Foreverlad
Son of a ...
Stefan, thanks a ton.  I completely forgot about the Cleanup options.  Perfect (and far too simple) solution to my problem.
