#1 2010-07-15 20:36
dimamak
Reverse "ddmmyy_xx" to "yyyy-mm-dd_xx"
Здравствуйте.У меня проблема с английским,поэтому пишу по русски.
Изучив материалы форума,почитав справку,я поэкспериментировал,
но ничего хорошего не получилось.Поэтому обращаюсь за помощью-
помогите со скриптами.
1.Необходимо переименовать все файлы:  ddmmyy_xx.jpg  to  yyyy-mm-dd_xx.jpg
2.Необходимо переименовать все папки с подпапками:
   ddmmyy_xx  to  yyyy-mm-dd_xx
   или
   ddmmyy  to  yyyy-mm-dd
С уважением, Дима.
#2 2010-07-15 22:29
Re: Reverse "ddmmyy_xx" to "yyyy-mm-dd_xx"
Well I'm not understaning almost anything but I'll try t make a question....  lol
yyyy?
A) ...1999 & 2000...
or
B) 2000...
#3 2010-07-15 22:35
Rule RegEx
Exp: ^(\d\d)(\d\d)(\d\d)
Rep: 20$3-$2-$1
#4 2010-07-16 17:22
dimamak
Many thanks Stefan!!!
But...
1. If to import files from folders it is excellent.
2. If to import a folder with files the folder is renamed, and files are not present.
3. If to import a folder with enclosed folders+files it is renamed
Only the main folder, and all that inside is not present.
P.S. Transfer has made http://www.translate.ru
P/S. I do not know as to attach screen ReNamer pictures
Thanks.
#5 2010-07-16 19:19
Hi dimamak,
Простите!, ... if i understand you right...
take an look on FILTER, please see >> http://www.den4b.com/wiki/ReNamer:Menus … lters_menu
And for to post picture please see >> http://www.den4b.com/forum/viewtopic.php?id=448
P.S. there is also an russian version of ReNamer >> http://www.den4b.com/downloads.php?project=ReNamer
if that helps.
If you have more questions or need more help please ask (maybe in german?)
(You can wait an week or so till Denis is back from vacation too, then he may talk to you in russian)
До свидания! (dasvi'da:nja )
But...
Thanks.
