I have a series of image files in 1 folder and I want to view them in order in an album
the file names are from 1 to 100 look like this
however it is displayed as this order when I view the slideshow
I have thought of a way to solve this which is use 3 digits to specify the name as
so I'll only need to change 1-9.jpg to 001-009.jpg and 10-99.jpg to 010-099.jpg
I tried with those expression but couldn't get any change on them. Can anyone help me please
Thank in advance
If your real file names really contain no numbers, only those at the end, then the simplest way would be:
1.) Add all files in ReNamer in the right order 1,2,3...10,11,12...
2.) Rule STRIP [X] Digits
3.) Rule SERIALIZE [Start: 1] [Step: 1] [Pad: 3] Prefix
4.) Preview
5.) see if all as you want
6.) Rename
Did that works for you?
If the files are not sorting in the order you want, select the "Sort in natural order..." check box
(Options menu, General tab)
@Stefan My files are already like this
so I can't just add more index number after. It wouldnt work
@narayan my viewer on ipad doesn't read it the natural way but thanks anyway
The trick is to first remove all digits from the file names and then add an new, fresh numbering with parameters that suit your needs.
Please note that each Rule does NOT rename the files immediately, but calculate an result and provide an Preview only.
Only if all Rules are done and you are satisfied with the Preview at last YOU will click on Rename.
So step 2 will maybe warn about files with same name, but step 3 will correct this.
If you have not provide good example names and your real file names will contain digits at other places too, then will do it with an other solution!
But this all belongs to the quality of how you request your requirements.
4.) Preview
6.) RenameDid that works for you?
OK, i do it
If your real file names really contain other digits than the numbering at the end:
2.) Rule RegEx
Express: (.+\D)\d+
Replace: $1
3.) Rule SERIALIZE [Start: 1] [Step: 1] [Pad: 3] SUFFIX
4.) Preview
6.) Rename
An other possibility way would be to just add an new numbering in front:
1.) Rule SERIALIZE [Start: 1] [Step: 1] [Pad: 3] PREFIX
hey guys
sorry for the late reply I've been busy last week
I think I can do it now, apply both of your methods so thank you all
just one more thing, is there a way to exclude 1 file from the renaming process? Cuz I actually have to do batch renaming for like 50 folder and I wanna automatically exclude this file "bia.jpg". It's always listed as first and so renamer would give something like this
I would like to have it start at the second file in my folder only. So is there a way to do it?
thank you all
have a nice day
[...] I wanna automatically exclude this file "bia.jpg".
Hi b.,
please see if this could work for you:
3.) Rule SERIALIZE [Start: 0] [Step: 1] [Pad: 3] Suffix
4.) Rule Replace: Replace all "bia000" with "bia" (skip extension)
5.) Preview
6.) see if all as you want
7.) Rename
@Denis, @All
More elegant would be an PascalScript command "Skip all following Rules and continue with next file"
Then we could do:
2) Rule PascalScript "If (FileName ="bia.jpg") Then SkipAllFollowingRules()"
3.) Rule STRIP [X] Digits
4.) Rule SERIALIZE [Start: 1] [Step: 1] [Pad: 3] Suffix
5.) Preview
8.) Rename
Maybe nifty too for
Rule PascalScript "If (WideExtractFileExt(FileName) ="EXE") Then SkipAllFollowingRules()"
Or did i miss here something?
Ah, an other way to exclude "bia.jpg" from renaming would be:
1.) Add your files
Now select from context menu (Right mouse click into files list):
2.) > "Mark > Invert Marking" to un-mark all files
4.) > "Clear > Clear Marked" to remove all bia.jpg from file list
5.) > "Mark > Invert Marking" to mark all of the left over files again
How easy is that stupid me!
thank for the help Stefan. I really appreaciate it
Have a nice day you all!!
