I found one thing in the Regex I would like to be changed.
I have sorted my Music in this way
[First letter albumartist]\AlbumArtist\Album\Discnumer\tracknumber - Trackname
I have a tagging program that can do all this for me, except the first part.
Example (Folder name "Cat Stevens"):
Find: ((.).*)
replace with: $2\$1
This gives:
C\$1
It should be C\Cat Stevens
I made another regex:
$1\$1$2
Result:
C\$1at Stevens
So the problem is, a expression ($n) can only be used once.
Is it posible to change this to unlimited use, so the var is not cleared?
Hi welcome.
Find: ((.).*)
replace with: $2\$1
This gives:
C\$1
Please note that the backslash \ is an regex meta char
and it will "escape" the next char "$" from it special meaning and give you an literal "$".
If you want to insert an literal backslash "\" into an regex
you have to escape this backslash from its special meaning
by prefix it with an another backslash "\\" :
Example
Rule RegEx:
Expre: (.)(.*)
Repla: $1\\$1$2
can someone be more stupid?
one of the key features of regex, escaping characters.
Thanx....
(of course it works...)
