I have this kind of files.
something.102.something_else
something.1102.something_else
So I would like a rules for changing in this way:
.102. --> .s01e02.
.1102. --> .s11e02.
So if there is 3 digits add s0 before the first one and e before the last 2 digit
If there is 4 digits add just s before the first two and e before the last 2 digit
Thanks in advance.
_________________
Do, or do not. There is no 'try.'" -- Jedi Master Yoda
something.1102.something_elseSo I would like a rules for changing in this way:
.102. --> .s01e02.
.1102. --> .s11e02.So if there is 3 digits add s0 before the first one and e before the last 2 digit
If there is 4 digits add just s before the first two and e before the last 2 digitThanks in advance.
if your file names are really as your examples,
i.e. the shown digits are the only digits in the whole name,
then this two regex may work:
something.s01e02.something_else
something.s11e02.something_else
DO:
--- match four digits
1) RegEx: Replace expression "(\d\d)(\d\d)" with "s$1e$2" (skip extension)
--- match three digits
2) RegEx: Replace expression "(\d)(\d\d)" with "s0$1e$2" (skip extension)
HTH? ![]()
Just for the record:
i had problems using this regex which should each match three digits only:
RegEx: Replace expression "(\d)(\d\d)\D" with "s0$1e$2" (skip extension) - three digits following by one non-digit sign
RegEx: Replace expression "(\d)(\d\d)\." with "s0$1e$2" (skip extension) - three digits following by an literal dot
So i match first four digits, and then in an second step three digits.
EDIT:
forget it ;-)
i was trapped once again by (skip extension) ![]()
Because remember: all after the first dot is taken as "extension"!
Un-checking "skip extension" solves my problem
So that is what i was after because the match is more error-save by matching the dots too:
DO:
--- match an dot followed by three digits followed by an dot
1) RegEx: Replace expression "\.(\d)(\d\d)\." with ".s0$1e$2."
--- match an dot followed by four digits followed by an dot
2) RegEx: Replace expression "\.(\d\d)(\d\d)\." with ".s$1e$2."
-- Remember: Un-checking "skip extension" !!! in your case with so many dots in the file name
Happy ReNaming
Thanks, I will test this when I'm home and I keep you informed.
_________________
It's working.
Thanks Stefan
_________________
Thanks for the feedback ! ;-)
