#1 2011-04-27 10:55
skiwi
EXIF not read of folder name is unicode.
When my folder name is Taupō my rule
Insert ":EXIF_Date:" as Prefix
faile to extract the EXIF data.
Yet if the Folder Name is Taupo it works fine.
Using WXP SP3 ReNamer 5.50 (3 May 2009)
#2 2011-04-27 14:48
Re: EXIF not read of folder name is unicode.
FYI, one of the first betas after full 5.50 release ( it was between ReNamer 5.50+ Beta 1 till  Beta 19 )
had an improvement related to this:
* Image_* meta tags can handle Unicode filenames, except for TIFF files;
So i think its worth to download the latest beta and see if this works better for you.
#3 2011-04-27 17:56
ReNamer 5.50+ Beta 1-19
Looks like the Beta is still going to give the same problems with the TIFFs.
I think it's an external plugin, and that's why it hasn't been fixed yet.
#4 2011-04-28 03:37
You guys got it right on target.
I just revisited this issue and fixed it for TIFF files as well. Image_* and TIFF_* tags for TIFF files will now work on Unicode filenames.
