#1 2011-06-22 16:20
JohnnySH
Rename with duplicated serial numbers
Hello
I have a complete directory of files that I need to add a serial number, but I would like it to step by 2 before it increments to the next sequential number. like below
They are like this...
SF300-Aggro Santos & Kimberly Walsh - Like U Like.cdg
SF300-Aggro Santos & Kimberly Walsh - Like U Like.mpe
SF300-B.O.B - I'll Be In The Sky.cdg
SF300-B.O.B - I'll Be In The Sky.mp3
I would like them to be like this...
SF300-01 - Aggro Santos & Kimberly Walsh - Like U Like.cdg
SF300-01 - Aggro Santos & Kimberly Walsh - Like U Like.mpe
SF300-02 - B.O.B - I'll Be In The Sky.cdg
SF300-02 - B.O.B - I'll Be In The Sky.mp3
and so on to the end...
Please can you advise how to do this in renamer
Thank you
#2 2011-06-22 18:08
Re: Rename with duplicated serial numbers
This will probably will need from PascalScript.
But, from the names you have, have you thought the method to insert the number in that place?
I mean, is not the same if you always have "SF300-" at the begining, or it does change for the rest of names.
The number could be inserted in a fixed position (e.g.: position: 7), or for example, after the first dash.
#3 2011-06-22 18:09
ponytail bob
I've been doing karaoke on a computer for 10 years now.
Don't know if Renamer will number as you want without doing the mp3's & cdg's seperatly, but the way i would handle that is download down load MP3+G Toolz (free program) & use that to turn them into zips.
Then use Renamer to  serialize the sequential numbers using position, then insert the "( - )". After renaming them use MP3+G Toolz to extract & both files will be renamed as you want them.
MP3+G Toolz is a must for karaoke on a computer. It will rename from numbers off the internet, clean file names & more with a simple right-click on the ciontaining folder.
If you need help in other areas with your show, feel free to email me
#4 2011-06-22 18:21
This will give you the numbers, but not positioned. If this isn't useful I'll need you to answer my previous question.
  Repetitions = 2; // Number of repetitions.
  Num, Rep: Integer;
  Rep := Rep + 1; // Current repetitions.
  {Check if needs to update/add.}
  If (Rep>Repetitions) then
    Rep := 1; // Restart repetitions.
    Num := Num + 1; // Serialization.
  {Write the number in front of the name.}
  FileName := IntToStr(Num) + FileName;
#5 2011-06-22 19:16
JohnnySH
thank you to everyone, appreciated
I have chosen ponytail bob route, this works very well
Thanks again
#6 2011-06-22 19:18
JohnnySH
Under the serialise option in Renamer, it would be great to have a skip option that you could adjust (offset) so that it would do this task before incrementing the next number.
Just a thought for a future upgrade
#7 2011-06-23 12:10
