#1 2011-06-22 20:41
JohnnySH
Skip feature under serialise numbers menu
please can we have an extra option under serialise so it will keep the same number (pre set by user) before incrementing to next serial number.
i.e. so I can rename my files like so.
They are like this...
SF300-Aggro Santos & Kimberly Walsh - Like U Like.cdg
SF300-Aggro Santos & Kimberly Walsh - Like U Like.mpe
SF300-B.O.B - I'll Be In The Sky.cdg
SF300-B.O.B - I'll Be In The Sky.mp3
I would like them to be like this...
SF300-01 - Aggro Santos & Kimberly Walsh - Like U Like.cdg
SF300-01 - Aggro Santos & Kimberly Walsh - Like U Like.mpe
SF300-02 - B.O.B - I'll Be In The Sky.cdg
SF300-02 - B.O.B - I'll Be In The Sky.mp3
this feature would rename 2 files with 01 as a serial number before the 3rd and 4th file got renamed with 02
it would be great if the user could set the number of skips before increment, in this case it would be 2
#2 2011-06-23 12:08
Re: Skip feature under serialise numbers menu
I've added "Repeat" option to the Incremental Serialize rule. Try the latest development version.
If you can, please test it in combination with other serialize options, to make sure that it performs as expected and does not contradict with any other options.
For the reference: this suggestion originated in Rename with duplicated serial numbers.
