Tested with the latest beta under Win7 SP1 x86.
Open custom dialogs such as Settings / All Settings, Settings / Filters, Presets / Save As, Presets / Create Links etc. Now press Alt+Tab and you'll see that ReNamer has completely disappeared from the active applications list! As long as those dialogs are open, you simply cannot Alt+Tab back to ReNamer at all, and have to activate it with the mouse.
Can't believe I didn't spot this earlier, or maybe it's due to a recent change in the beta. In any case, this needs to be fixed.
I'm using XP SP3 and seems to be ok using alt+tab key combination. Active was Opera, ReNamer, some folder window... Maybe there is an issue with Win7 ![]()
I'm getting problem with Analyze dialog disappearing but will not spread the thread... It's already on to do list...
@eR@SeR: Did you try to Alt+Tab after opening one of the program's dialogs mentioned above? If it works, then it's definitely an issue on Win7 only (and maybe Vista, if someone can check). BTW, I confirmed that the same bug exists on Win7 SP1 x64 as well.
Yes off course. I tried with all mentioned dialogs and everything is ok. I would like to see other users opinion about this issue... I have latest beta (53).
Yes please, can others using Vista (and Windows 7 especially) confirm this and report back? Of course, I did check on multiple systems before reporting, so it is not something specific to a single broken OS install. Something has surely changed in how these custom dialogs are treated by Windows, and this needs to be addressed by Denis.
