#1 2011-08-10 10:28
leeroy
Guest
Presets available from the contextmenu (Explorer right click)
Hi
Been using Renamer a while and think its great.
I still have an old 64-bit context menu extension on my system called "awxrename" purely because easy context menu access to certain presets.
For instance I select a few files in explorer & riht clickthem then under that context menu entry I have options: Lowercase, Uppercase, Mixedcase, Strip Spaces
Dots to Spaces, Spaces to Dots, Spaces to Underscores, Underscores to Spaces.  Select one & it just does it. The point is easy access, simple and fast.
Can do stuff in 2 clicks that would otherwise require launch Renamer, drag & drop files (multi windows open), create rule or select preset, close Renamer.
What I am suggesting is Renamer adds another tick box to its saved presets maybe called "show on context menu". Only ticked items show up cascaded on the context menu. Then user can create Renamer presets to do the identical to above or even something more complex - eg whatever their most common/favorite presets are.
Maybe others have some tweaks to improve on the basic functionality I'm suggesting?
Keep up the good work, is great program - much better than some fully paid for commercial stuff!
Cheers
Leeroy
#2 2011-08-10 17:07
Re: Presets available from the contextmenu (Explorer right click)
Hi Leeroy,
You can do this by placing links to presets in to the "Send To" menu.
Look for "Create Links" option in the Presets menu:
ReNamer:Main_Menu_and_keyboard_shortcuts#Presets_menu
