#1 2011-08-16 15:51
crystal3d
Replace: meta tag "File_FolderName" with "sometext_FolderName"
Greetings,
I want to rename files that have same name as its folder only,
tried my luck with using a meta tag on the find panel instead of the replace panel:
not suprisingly, it did not work...
if it did, i could rename 9000 models...
is it possible to get it done via pascal script or alike inside renamer?
#2 2011-08-16 19:48
Re: Replace: meta tag "File_FolderName" with "sometext_FolderName"
I think this should be easy with PascalScript, but I found something unexpected.
One question for Denis: Shouldn't WideExtractFileDir() return the folder name instead of the folder path? for the folder path there's already WideExtractFilePath(), isn't it?.
#3 2011-08-16 20:57
crystal3d wrote:
Greetings,
X:\Path\to\Test\Test.ext
X:\Path\to\Test\File.ext
X:\Path\to\Test\_Test.ext
Try:
  ParentFolder,FileBase: WideString;
  ParentFolder := CalculateMetaTag(FilePath, ':File_FolderName:');
  FileBase := WideExtractBaseName(FileName);
  if (FileBase=ParentFolder) then
     FileName := '_' + FileName;
If Parent and File have different case,
X:\Path\to\Test\test.ext
X:\Path\to\Test\_test.ext
Try:
  ParentFolder := WideLowerCase(ParentFolder);
  FileBase := WideLowerCase(FileBase);
but the file should get the same case as the parent folder
Try something like:
     FileName := '_' + CalculateMetaTag(FilePath, ':File_FolderName:');
HTH?
#4 2011-08-16 23:31
Here is a good article which gives examples of how functions like ExtractFileDir behave:
http://www.delphibasics.co.uk/RTL.asp?N … actFileDir
I have also fixed the description of these functions on the Wiki:
ReNamer:Pascal_Script:Functions#File_Name_Utilities
To extract folder name of a file, you can use this snippet:
FileName := WideExtractFileName(WideExtractFileDir(FilePath));
#5 2011-08-17 08:19
crystal3d
Bull's eye! DTH! smile
#6 2011-08-17 08:54
crystal3d, thanks for the feedback!  (your long quoting will be removed later wink )
Thanks big_smile
Added to the wiki http://www.den4b.com/wiki/ReNamer:Pasca … :SplitPath
(re-formating allowed  tongue )
